Y do ppl put MSD boxes under the hood?
Old Feb 15, 2001 | 12:14 PM
B84305-Streetmachine's Avatar
cant it get screwed up from heat and moisture under the hood?..i dont trust the sealent on anything cause nothing created to seal holds forever.
does anyone think it would be better to mount on the firewall inside the car or in the center console or somewhere inside???
when i put one in my old mopar i put it in the glove compartment.
anyone?
AIM: grvkill
ICQ: 29298583
Old Feb 15, 2001 | 01:25 PM
85berlinetta's Avatar
My friend puts one in a 78 trans am. He tried to hide it by putting it under the glove box assembly. Works good, but makes a real anoying buzzing sound. It is kinda loud too. I have seen a lot of them mounted under the hood, and as long as you don't put it in what you know is harms way I don't think there will be a problem.
Old Feb 15, 2001 | 01:27 PM
theformula's Avatar
I've had mine behind the drivers side strut tower for over a year with no problems. I eventually want to install it in the car . Make sure it is laying down flat like it's supposed to. This is what an MSD tech told me.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN93, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL, Holley 9mm wires, fastchip, Bosch O2sensor, Bosch in-line pump(w/stock pump), SLP headers & catback,short shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Feb 15, 2001 | 04:54 PM
The ODB's Avatar
You are right.
I mount my electronics under the dash on the passenger side of both my cars. Have been running one MSD for 10 years and the other for 6 years and never a problem.
ODB
[This message has been edited by The ODB (edited February 15, 2001).]
Old Feb 15, 2001 | 09:31 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
I wouldn't put that thing too close to the computer though. It might emit EMI/RMI and daze&confuze it. I bolted mine (Holly Anhillator) right to the console next to the e-brake. It buzzes but with solid motor mounts and loud exhaust and spherical mounted rear axle sending whine right through the floor i really don't care.
[This message has been edited by JoelOl75 (edited February 15, 2001).]
Old Feb 15, 2001 | 11:34 PM
The ODB's Avatar
Good point about the computer... I forgot.
My camaro is a "computer free" zone.
Old Feb 16, 2001 | 11:31 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I have mine on my passenger front strut tower, where my coolant bottle used to be. (I replaced the bottle with a smaller one). Seems fine to me so far!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Feb 16, 2001 | 12:13 PM
84FTA's Avatar
I wouldn't be worried about rain. Go out on a day it's pouring, then pull in the garage. 95% under the hood will be dry (and I have an open turbo hoo!). I wouldn't be worried about rain and moisture. The only thing I would worry about is blowing a coolant hose. Those usually do a good job of soaking everything heavily with a very hot stream of water/antifreeze.
1984 WS6 Trans Am Hartop
Former L69 Car under restoration
1984 Trans Am T-tops
4-bolt main 350, performer intake, headers, Holley 650, T-5, hayes clutch, dual elec. fans and 3.23's.
Daily driver and restoration
13.98 @ 101
Old Feb 16, 2001 | 01:23 PM
'89Formula305TPI's Avatar
I mounted it here.
sorry for that large pic (dunno how to enlarge it)
'89 Formula 305 TPI T-5
Check out my car HERE!
[This message has been edited by '89Formula305TPI (edited February 16, 2001).]
Old Feb 16, 2001 | 11:19 PM
82z's Avatar
82z
I put mine underneath the charcoal canister. I haven't had any problems with it there. If you do mount an ignition box in the car you have to make sure it has adequate ventilation to prevent overheating.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old Sep 3, 2001 | 07:24 PM
speedlvr's Avatar
<font face="Verdana, Arial" size="2">Originally posted by theformula:
</font>
The MSD instruction booklet on page 4 says you can mount it any way but upside down.
Old Sep 4, 2001 | 06:51 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Why? I guess the simple response would be why not. MSD builds the circuitry of their boxes assuming underhood conditions (and offroad too), it then additionally coats the boards. Grab one and inspect it carefully and you will note it is not a hermetic seal (not even close!). It was designed that way so the box could 'breath'. Pretty good box.
Mounting it near a computer should not be a problem the boxes are analog and I have yet to see EFI/RFI caused by one.
MSD really doesn't care which way you mount it so long as it is not upside down. When you mount it like that condensation and any water that gets in has a very difficult time escaping.
BRoss99
Aug 10, 2025 05:08 PM
9192camaro
16
Feb 3, 2019 12:21 AM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
bryan623
Aug 10, 2015 11:33 AM
