Tow a van with the 3rd gen???
Old Jun 13, 2005 | 09:50 AM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
Just wondering if it would be possible for about 15 miles. My buddy has a broken down 85 van (probably about 3700 lbs) that we want to tow with a dolley up to my house to fix.
Is this going to work? Has anyone attempted to tow THIS much weight? I have a 2000 lbs hitch and have successfully towed a 94 Pontica sunbird accross town to the junkyard. But the van is above and beyond the sunbird's weight.
The tongue weight with the tow dolley is just about zero, if not even negative somewhat. And the camaro has subframe connectors.
Old Jun 13, 2005 | 10:14 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Hhhhm, does not look like a good plan to me. First, a trailer hitch on a thirdgen is akin to putting one on a boat. Looks useful, but really isn't practical. Your brakes are woefully inadequate to the task, and you are going to be seriously exceeding the capacity of your transmission.
Can you do it? If you tow in second, or third gear, go slowly, brake well in advance of when you think you need to, you might be able to get away with it. The van probably weighs twice as much as the pontiac. If there is another alternative, I would look real hard at it.
Old Jun 13, 2005 | 01:01 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Your not exceeding the capacity of your transmission if you have a 700R4
Old Jun 13, 2005 | 01:23 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
You guys are sounding like fNord truck owners, "I cant tow that with my F150, I need at least a F250".
It will be fine. I do question the hitch weight capacity since thier not that much different then the ones they use on carivans also 2k/2.5K. You see those people hauling all kinds of stuff around in those little vans.
I wouldent worry about it just go slow and do it when theres light traffic.
Old Jun 15, 2005 | 12:56 AM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Good advice. Brake lightly and well in advance. Drive like your grandma, go SLOW and accelerate gradually. I'd say keep it to 45 mph tops.
I've towed a light catamaran with my IROC, it does fine, just be gentile.
Old Jun 16, 2005 | 01:09 PM
rudyt5000's Avatar
Car: 87-Z r.i.p & 93-Z sold 99s-10
Engine: 305 TPI , 350 LT1, 2.2 4cylinder
Transmission: 700 R4, 4l60, ?
hmm i towed so many cars before vans, trucks, cars , no problem but i think its cause i used a tow rope not a hitch...i think the motor and tranny should be fine...i pulled a Big A** flat bed ford truck i think before with now problem ...
Old Jun 16, 2005 | 05:44 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
How do you figure? Same 700R4 that was in all 80's and early '90's full sized Chevy trucks.
A agree that cautious driving is in order, but the engine and trans are the same as a 1500 truck, and the brakes are better.
-Tom
Old Jun 16, 2005 | 06:11 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
My friend was just telling me a story of them hitching another car with a a car and everything was a ok until. He said he wasnt even going 10 miles an hour and turned a corner and the car he was towing kept going straight and pushing his back end with it.
Old Jun 16, 2005 | 08:15 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
-Tom
I was just responding to a post higher above saying it would hurt the transmission. I said it would NOT hurt the transmission. I was saying that it wasn't above the capacity. Heck I have the same transmission in my G20 and it has towed its 8,000 lbs trailer rating many times. That would be 13,000 lbs with 3.08 gears and a 305.
Old Jun 16, 2005 | 11:21 PM
rudyt5000's Avatar
saggy 56 yall must of done something wrong cause i been towing bout a ton of crawfish all summer long and never had a problem with it going straight ...but its just maybe a third gen aint meant for a hitch but it can pull almost anything i'll tell you that...and i fit 9 people in it and still drove aight till i hit speed bumps at the border
Old Jun 17, 2005 | 02:51 AM
shaggy56's Avatar
Car: 71 Nova
Im just telling you what happened. I dont think they did anything out of the ordinary. They were very surprised it happened.
Old Jun 17, 2005 | 08:51 AM
mdricken's Avatar
Car: 92 Camaro
I'm using a tow dolly so it should act just like a trailer. And we are going to load the rear end of the van on the dolley so the weight is all out back.
I'll let you guys know how it goes this weekend
Old Jun 17, 2005 | 12:36 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
the rating on the hitch is for tung weight, your cars max towing rating is for the total amount u are towing for braking reasons, you should be able to tow the van with no problem, just make shure u give urself alot of breaking room, and i would say go 45 max. and i would load the frunt of the van on trailer it will put more weight on ur rear tires and help with braking
ps excuse the spelling
ex-x-fire
Jan 12, 2024 01:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
Ozz1967
Aug 16, 2015 10:23 PM
