Stupid accell runners.
Old Aug 28, 2001 | 03:18 PM
evilho7810's Avatar
I bought a set of runners used without the hardware and the stock bolts aren't long enought and regular bolts won't work. Does anyone know where I can get torx or allen head bolts in a metric thread? I've tried every hardware store in chicago and nothing this is sooooooo anoying!!
Old Aug 28, 2001 | 04:49 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
From memory they are 10mm, 'standard' metric thread. I bought a couple of regular hex head bolts in this size at home depot a while back. You'll need to find a good hardware supply to track down allen head ones though.
Old Aug 28, 2001 | 04:50 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Try a real bolt & screw place, industrial supply type of thing
ICON Motorsports
Old Aug 29, 2001 | 01:13 AM
age's Avatar
age
Car: 1992 Z28 1LE
Try using the old hardware, because I have the Accel runners and I used the old hardware..
Old Aug 29, 2001 | 01:14 AM
age's Avatar
age
Car: 1992 Z28 1LE
but I think you might run into problems with the long bolts at the bottom...I'll have to double check and look at my setup again.. I do recall using the stock ones for the shorter bolts.
Old Aug 29, 2001 | 12:31 PM
evilho7810's Avatar
They are 8mm and the bottom bolts are the ones that are giving me problems. They need to be like 3 1/2 inches long. I'm going to try a real industrial place if they will sell to me.
Old Aug 29, 2001 | 07:18 PM
irocbsa's Avatar
Hell, mine were too long at the top and not long enough at the bottom. YOu'll definitely have to go to a good fastener store. I had to search a little to find mine.
bsa
Old Sep 5, 2001 | 07:26 PM
evilho7810's Avatar
They want me to buy a whole box of these damn bolts!!! 40 bucks for 4 bolts!!! Does anyone work at a machine shop that might have 8mm by 3 1/2 allen head bolts?
Old Sep 5, 2001 | 09:43 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Try Ace hardware... I just bought some of those 8mm socket head bolts. With the allen heads for my SuperRam install. They had a bunch of different lengths.
Black 90 IROC:406SB
Trickflow 23* heads
SuperRam
[This message has been edited by MikeH (edited September 05, 2001).]
Fanatic1074
Oct 3, 2022 05:57 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Chas91Z28
Oct 22, 2015 10:12 AM
djmarch
Oct 2, 2015 10:41 PM
efiguy
Sep 27, 2015 01:30 PM
