cold start problem
Old Jun 14, 2005 | 09:56 AM
PAformula's Avatar
cold start problem
Lately my '89 Formula with a 350 TPI and 120,000 miles has been very hard to start cold, It usually take a couple(4-5) tries to get to run. It will start up and die right away. I replaced the old dist. cap & rotor, but that didn;t solve the problem. I searched the boards but didn't find anything. What else should i look for? clogged EGR?? bad Temp. sensor???
I have little spare time and money anymore since I just had a kid. Any help would be greatly appreciated.
Thanks,
Jason
Old Jun 16, 2005 | 09:52 AM
Vader's Avatar
How is the fuel pressure?
Old Jun 16, 2005 | 11:10 AM
PAformula's Avatar
i never checked it, but it runs ok once you get it running.
Old Jun 20, 2005 | 10:57 AM
PAformula's Avatar
Could it be the cold start valve on the fuel rail? Is that the same as the cold start injector on earlier TPI systems? Has anyone had to replace a cold start valve before? What were the problems?
Old Jun 20, 2005 | 01:31 PM
tph87's Avatar
Car: '87 iroc z-28 5.7 tpi
Engine: 5.7 tpi
Transmission: auto
hey. My 87 IROC does the exact same thing!
i haven't found any answers form anyone yet, i hope someone can help us
Old Jul 11, 2005 | 03:31 PM
tph87's Avatar
Engine: 5.7 tpi
Transmission: auto
have you got your problem fixed yet?
i haven't,
Old Jul 11, 2005 | 03:36 PM
PAformula's Avatar
Yes, It was the dreaded fuel pump. My old pump was only producing about 24 psi. (about 10 psi under spec.) I just finished the PITA job yesterday. All I have to say is - what was GM thinking?...
Old Jul 15, 2005 | 08:50 AM
tph87's Avatar
Engine: 5.7 tpi
Transmission: auto
how bad was it? what all did you have to do? and what was the expences?
Old Jul 15, 2005 | 09:07 AM
PAformula's Avatar
It was bad. Do a search on fuel tank removal and I'm sure you'll find many posts on the subject. I went with a GM pump for about $150. Don;t even think of buying a cheap pump, it was way too much work to have to do it again. I also had to buy a new strainer ($6) and new sway bar links($12) that I broke getting them off. Be absolutely sure you need a pump first, check your fuel pressure at the fuel rail, you should have 34-47 psi, i think.
good luck
Old Jul 16, 2005 | 06:16 PM
OneGravenKiss's Avatar
Car: 1986 WS6 Pontiac Trans Am
i feel you on the fuel pump removal i had to enjoy the pleasure of doing that and the cold start for me was the cold start injector.
Old Jul 20, 2005 | 04:07 PM
tph87's Avatar
Engine: 5.7 tpi
Transmission: auto
where is this cold start injector? and what does it do?
thanks.
92camaroJoe
Jul 29, 2023 07:57 PM
Wade787b
Sep 29, 2015 01:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
