ecm wire
Old Sep 5, 2001 | 04:33 PM
fourspeed's Avatar
ecm wire
i was going to check the timing and the hood decal says to disconnect a tan and black wire before checking. i found a wire near the battery and when i disconnected it the engine died. is this the correct wire? i need someone with and 86 IROC tpi to let me know
thanks
86 IROC 305 TPI, KYB shocks, poly bushings, alochol/water injection, MSD, K&N, map relocated, Flexalite dual fans, 1.6 rollers, March pulleys, ported plenum, overlays, cat gone and 3 inch flowmaster into 2 2.5pipes, MSD 300+ wires and platinum plugs, 170 thermostat, gutted air box and all free mods, (in storage for 15 years)
Old Sep 5, 2001 | 06:36 PM
sunbitz's Avatar
Car: 91 RS Convertible
Engine: 305 TBI
I think the wire you are looking for is on the pass side of the distributor. There's a plug there.
You have to disconnect that wire to play with the timing.
Old Sep 6, 2001 | 12:40 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
Check this old post. It has a picture of the EST by-pass connector.
https://www.thirdgen.org/messgboard/...ML/001499.html
stalkier
Dec 6, 2015 11:25 PM
Jae992
Aug 27, 2015 09:07 AM
djmarch
Aug 19, 2015 12:07 PM
stalkier
Aug 13, 2015 12:59 PM
marcusaw
Aug 10, 2015 08:13 AM
