How can i tell if valve lash is too tight?
Old Jun 15, 2005 | 11:42 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I just got done with my cam/head swap and i am worried that i might have the vavle lash too tight. Is there anyway that i can tell? I used the method where you spin the pushrod then tighten it will you cant spin it anymore.
Old Jun 16, 2005 | 01:50 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: How can i tell if valve lash is too tight?
I'll pretty much guarantee they're too tight then. If you're going to use that method, you do it until you can just feel a slight drag as you turn the pushrod, not until it doesn't turn anymore.
Old Jun 16, 2005 | 03:53 AM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
mine may be too loose, but they're not making any noise yet. I had trouble getting my car started after a cam/head swap. So the lifters ended up being pumped up. I adjusted mine just to the point all verticle movement of the pushrod was out. Didn't even give it 1/4 turn. I was figuring after I got the car running I'd adjust the noisy ones. None of them were noisy
Old Jun 16, 2005 | 05:54 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If you cranked em down to where the push rods can't spin, they're too tight.
Back them all off exactly one full turn; and then adjust them correctly with the engine running.
gta892000
Aug 11, 2019 11:16 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
dimented24x7
Sep 6, 2015 03:51 PM
