No spark...
Old Jun 16, 2005 | 06:19 PM
RED92Z28's Avatar
Car: 92 Z28 TPI
Engine: 305HO
No spark...
Yesterday I bought a 92 Z28 305 HO w/TPI. On Tuesday I heard it run. Here's the problem - I now have no spark. So far I have replaced the ECM (no self-diagnosis), distributor cap, rotor, ignition module, and coil. What else should I look for? Everything I can find is plugged in. I replaced a couple of vacuum hoses also. I tried to test the coil, but my meter has crapped out also (not been a good day). I'm going to get a noid light to check the injectors, but that shouldn't have anything to do with the spark problem, should it?
HELP!! I'm in desperate need.
Thanks for any help.
Old Jun 16, 2005 | 09:51 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
No the injecctors will have nothing to do with spark. You may have a bad coil or distributor
Old Jun 17, 2005 | 04:04 AM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
take the coil to autozone or someplace like that. They'll test it. If it's good my money is on the ignition module. They **** out all the time. I had a car that wasn't starting after a cam swap. Had spark and everything else. Got the no start situation fixed then I had no spark. replaced the module and it fired right up
Old Jun 17, 2005 | 05:55 AM
RED92Z28's Avatar
Car: 92 Z28 TPI
Engine: 305HO
The coil and module were both replaced yesterday afternoon with new parts.
I have two other f-bodies, neither with FI. Now I know why. LOL
Old Jun 18, 2005 | 01:35 AM
RED92Z28's Avatar
Car: 92 Z28 TPI
Engine: 305HO
bump
silentkillzr
May 12, 2014 09:03 PM
maxjivi05
Jul 28, 2012 09:42 PM
bobbyk3lly
Mar 16, 2012 11:34 AM
fitojdj
May 30, 2011 10:35 AM
joker37
Jul 16, 2002 05:03 PM
