foglight bulb options
Old Jun 17, 2005 | 01:32 AM
86 sports coupe's Avatar
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
I looked through the search. I have an 86 sports coupe, I have the silver star headlights, they are great. Are the bulbs for the foglights just as good? As far as bulbs go( brightness) any suggestions for the foglamps?
Old Jun 19, 2005 | 02:08 PM
Vader's Avatar
If you have glass lamp housings (like the Pontiacs) and correct wiring/relay, you can install H-3 halogen bulbs. Oncoming drivers don't appreciate them if they are not aimed corretly, however, so do a complete job and check the aiming as well. IIRC, the OEM lamps are either 35 or 55W. I've got 100W in mine. Forget about the "blue" colored lamps, too. They don't add any light.
Old Jun 19, 2005 | 06:00 PM
I had cool blue headlights, I changed to silver stars, the light is so bright and white if I shut the car off and leave the headlights on, they do not dim. The silver stars make my cool blues look light a regulars headlight. My foglights look yellow when I turn the headlights on! H3 a direct bolt in?
Old Jun 21, 2005 | 02:47 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
UH OH!!!! I was not happy with the 55W so I also used 100W. It says on my bulb package that they were for off road use only. I guess I am not the only one who will have to look out for the light bulb police.
Old Jun 21, 2005 | 04:07 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
light bulb police suck. I got pulled over for failing to dim my brights when I had my foglights on in my volvo 940 turbo
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
gixxer92
May 18, 2017 11:20 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
