Im installing alluminum heads on my 305 TPI!!! please read inside, need info!!
Old Sep 8, 2001 | 02:54 PM
vortech305's Avatar
tomorrow im putting the 305 TPI together, Im putting the corvette alluminum heads on and i just ordered ARP bolts w/ washers. My question is this, anyone know what what the torque numbers are?? when i install the bolts on the heads, should i use some type of sealant, for ex. lock sealant anti seaze sealant, what should i use to get a good torque reading the bolts???. ONe more question anyone who has done this, is there anything i should look out for, before i do this, everything is from an 87'-88 parts, look at my sig. thanx
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
site to see my cars at <A HREF="http://www.geocities.com/iroc_dis/iroc_dis_page.html
1971" TARGET=_blank>www.geocities.com/iroc_dis/iroc_dis_page.html
1971</A> plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Sep 8, 2001 | 03:07 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
IIRC, the torque is 65 ft lbs.
Use Loktite brand PST liquid sealant with teflon on the head bolt threads.
"what should i use to get a good torque reading the bolts???. "
A torque wrench.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Sep 8, 2001 | 03:16 PM
kevinc's Avatar
Car: 1982 Z28
To add to what Engineboy said, use ARP moly lube on the headbolt washers...both sides. This cuts down the friction during torquing and gives a more accurate reading.
Torque in 3 steps following a circular pattern...first time with the torque wrenche set at 1/3 of the total torque, 2nd time at 2/3 of the total torque, and last time at the full load (65lb/in as Engineboy stated sounds right).
Seems like my last ARP head bolt kit came with an instruction sheet that included the pattern and torque value, but it's been a while.
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
