timing advance at idle
Old Sep 7, 2001 | 02:27 PM
blue91rs's Avatar
hooked my car up to the scanner today and the timing advance at idle is at 26*. Is that normal or is that way too high. I've never messed with timing before, but it seems like I'll be tackling it soon. Any input on why the timing is that high? I think I need an education on this. Thanks guys!
Old Sep 7, 2001 | 02:49 PM
iroc5speed's Avatar
wow that's a lot of idle advance. I'm running about 4 degrees advanced at idle.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
Old Sep 7, 2001 | 03:42 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That is your total advance, not the "base" advance. The computer advances it based on engine speed, throttle position, and load (vacuum).
iroc, the timing you quote is the "base" timing, set with the computer disabled. If you put the light on with the 4-wire connector reconnected, you'd find it advanced well above 4 degrees.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Sep 7, 2001 | 04:13 PM
blue91rs's Avatar
so is that a lot of computer controlled advance? While driving if I get on it, it will jump up to 36* at times, is this normal?
Old Sep 7, 2001 | 06:33 PM
rezinn's Avatar
Yeah.
Old Sep 7, 2001 | 11:59 PM
iroc5speed's Avatar
I have vacuum advance, not computer advance, note the msd in the signature.
'86 IROC 5-speed
305 LG4
'95 3.23 rearend
Old Sep 8, 2001 | 12:09 AM
breathment's Avatar
mine with the A&B term. jumped is about 20-25, and with it not jumped is about 10
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
Old Sep 8, 2001 | 12:31 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
<font face="Verdana, Arial" size="2">Originally posted by blue91rs:
hooked my car up to the scanner today and the timing advance at idle is at 26*. Is that normal or is that way too high. I've never messed with timing before, but it seems like I'll be tackling it soon. Any input on why the timing is that high? I think I need an education on this. Thanks guys!</font>
Was the car in Park or Drive when you checked?
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
-Currently collecting parts for T5 swap
Old Sep 8, 2001 | 11:30 AM
blue91rs's Avatar
the car was in park. what happened was I started it and right off it was advanced to like 27*. then as i gave it gas, the timimg went up to about 36*. the same occurs while driving, the timimng is advanced at about 28*, and if I got it I think I've seen the timing up at 40*. The other thing I was wondering is the knock sensor is retarding the timing about 9*-15* at WOT. Is this because the timing is so advanced that I'm gettting detonation? I'm running 93 octane. Any input?
87 IROC 305 TPI VIN F
Guttted cat- Flowmaster Catback
Old Sep 8, 2001 | 02:30 PM
blue91rs's Avatar
anybody?
Old Sep 8, 2001 | 05:10 PM
five7kid's Avatar
<font face="Verdana, Arial" size="2">Originally posted by iroc5speed:
I have vacuum advance, not computer advance, note the msd in the signature.</font>
But you were talking to a guy with computer controlled advance. CC uses a base timing that sounds close to a mechanical/vacuum advance system setting. But, what you have doesn't really apply to a CC system, especially if you use timed vacuum for your vacuum advance.
Blue, what's your base timing set at? Are you having any driving, power or pinging problems?
Old Sep 8, 2001 | 05:31 PM
blue91rs's Avatar
five7kid,
I'm not sure what my base timing is set at as I don't have a timing light. I would assume its at the factory spec. (not sure if thats 0* or a little advanced for my car)
I plan on purchasing a timing light in the near future and checking it.
Right now I'm trying to sort out a SERIOUS LACK of TORQUE in the lower rpms.
I've replaced the O2, wires, plugs, cap and rotor, CTS, Cleaned out the IAC, adjusted the IAC and TPS.
Am I looking at the right area for my symptoms?
O2 sensor works fine, goes into closed loop.
Car runs a little rich, the Block Learn reading stays around 120, and sometimes drops to 112, indicating that the car is running rich.
O2 sensor is at about 500mv-600mv when this happens.
As far as I can tell I've never heard an engine ping or knock of any sort, but I know that doesn't mean that its not occuring. Thanks five7.
[This message has been edited by blue91rs (edited September 08, 2001).]
Old Sep 8, 2001 | 05:36 PM
Engine: LH0 3.1L
[This message has been edited by CaliCamaroRS (edited September 08, 2001).]
Old Sep 8, 2001 | 09:16 PM
blue91rs's Avatar
eh?
Old Sep 9, 2001 | 12:35 AM
blue91rs's Avatar
ok, does anyone know of a post were I might find the awnser?
Old Sep 9, 2001 | 12:36 AM
blue91rs's Avatar
or a website? or a book? anything that might help?
Old Sep 9, 2001 | 01:01 AM
Engine: LH0 3.1L
</font>
I don't have your answer but you are supposed to check/set timing with the car in drive, not park.
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
Old Sep 9, 2001 | 09:51 AM
blue91rs's Avatar
drive/park, it was the same on the scanner, maybe 1* difference.
Thanks for the reply though.
Anybody?
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
