Is it possible to test spark with a volt meter?
Car: 1991 camaro RS
Engine: 305 Carb
i am having a slight miss in my engine under load, i just completed my TBI to carb swap and i am looking for a way to make sure my ignition components are up to par. Can it be tested with a volt meter and if so, how??
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The plug should have infinite resistance. If you want to test for spark, you can clip a timing light onto each wire, or pick up a spark tester for a couple of dollars.
Glowsock
Sep 6, 2015 06:40 AM
