slow slow slow slow slow slow
Old Sep 10, 2001 | 10:54 AM
Federico's Avatar
ok ,this is my car :
83z28 305
holley600cfm vac.sec.
K&N filter plus stubstack
edelbrock rpm performer
dynomax exhaust
dual snorkel intake
th-200c
new torque converter
2.73 rear
this is my problem:my car runs great only after 2,700rpm, before that point i don't have any power , the car runs flat.
I've tried almost everythings the carb is perfecly tune(no bogs or backfire) the base timing is set at 9° i've checked the rotor and cap (the only thing that i found a lot carbon deposit on the rotor and scratches on the cap terminal),cylinder compression
pressure is fine,i don't have the catalytic converter..
NOW i'm really frustrated
it takes 8.7sec. to lanch my car from 0 to 60mph ,i think it's too much.
I need some good advice cause i'm reeeallyy frustrated!
PLEASE HELP ME!
Old Sep 10, 2001 | 11:57 AM
89ProchargedROC's Avatar
get a gear
your car is stalling too high for you little 305. they dont have a whole lot of torque and with even a mild stall and that 2.73 gear it is going to feel like you are going no where FAST
Get a 3.42 or 3.23, you can go 3.73 too but you compromise mpg on the highway
Old Sep 10, 2001 | 02:12 PM
Federico's Avatar
If it's only a matter of gear i feel much better now but i think that my car should going faster anyway.
Is some one there with a similar car?
THANKS!!
Old Sep 10, 2001 | 02:38 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
How does your tranny shift, if it is slipping on the 1-2 shift that will severly hurt your 0-60 time, at least that's what happened to me until I had it corrected.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Sep 10, 2001 | 02:40 PM
Car: 99 Formula
Axle/Gears: 342
Are you using the stock manifolds, plus you have the stock dual snorkel intake which along with the manifolds isn't helping your engine breath. A big hinderance of 305's is the stock exhaust manifolds and air intake.
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
160* Stat
3:73 Posi
Rebuilt 700R4
Old Sep 10, 2001 | 03:12 PM
Federico's Avatar
NO... i've an edelbrock rpm performer mainfold with the dual snorkel intake (the one used in the 5.7 h.o.)
The tranny slips a little bit : i saw an increase of about 700rpm when shifting 1-2.
At which rpm should i run my engine from the standing position?
THANKS!!!!
Old Sep 10, 2001 | 03:56 PM
Car: 99 Formula
Axle/Gears: 342
I meant stock exhaust manifolds not intake manifold.
Old Sep 10, 2001 | 03:58 PM
Car: 99 Formula
Axle/Gears: 342
That 1-2 shift flare of 700 rpm's isn't helping your 0-60 time. Check the tranny boards for trannies slipping or how to adjust the TV cable. Transfixleo gives a very clear direction on how to properly adjust the TV cable, which will hopefully help your trannies shifting.
Old Sep 11, 2001 | 02:35 AM
Federico's Avatar
I've the stock ex. mainfold...
Transfixleo what is it?
Old Sep 11, 2001 | 05:20 AM
Jza's Avatar
Jza
transfixleo is a user who frequents the Transmission forum.
RedLeader289
May 28, 2019 01:47 PM
Elephantismo
Feb 13, 2019 12:51 AM
Ed1LE
Sep 30, 2018 09:14 AM
bjpotter
Oct 4, 2015 07:48 PM
Luigytico09
Oct 1, 2015 08:46 AM
