Question about aftermarket passide alternator bracket
Old Jun 23, 2005 | 05:38 PM
TWICEtheRICE's Avatar
Car: 91' Pontiac Firebird
Engine: 388 ci Small block CHEVY (4.060x3.75), Dart Iron Eagle Platinum 200cc, Performer intake, 454 TBI, Long Tubes, True Dual 3" GPs
Transmission: 700R4, B&M, Governer Recal, 20,000 GVW cooler
I need an alternator bracket, so I am looking at a passenger side mounted one, but it says the application is for SB chevys up to 1975. My engine block is from a 1990 suburban and the heads are aftermarket performance dart heads.
Put this part # in at TRD-9316 to see the bracket.
The belt routing would be just like replacing the AC compressor.
Thank you!
Old Jun 23, 2005 | 06:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Block and heads don't matter.
The thing that changed, was the intake. The early motors used a stud instead of a bolt at the pass side of the water outlet, and the bracket went there. The later system has the extra bolt boss on the front of the intake.
9317 is for the later style.
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
jahblah
Aug 12, 2015 05:54 PM
