Cams
Old Sep 12, 2001 | 09:30 PM
camaroguy2003's Avatar
Car: 1992 Camaro RS
Engine: 406 SB
Transmission: TH350
Cams
Ok, I need some advice. What would be my best bet for a 92 LO3? I would like a noticable lope at idle. Im looking into both roller cams, tappet cams and just an lt1 or lt4 roller cam. Any suggestions are welcomed. I dont have a lot of money to spend either.
Old Sep 12, 2001 | 09:50 PM
Dan87IROC-Z's Avatar
Well, I would suggest the smaller of the SLP cams from summit, thats what my friend used in his 89 RS. It does cost an arm and a leg though, but you can find a used one on Ebay for less than $100 I'm sure.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Accel High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, Jet TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
