should tpi fuel rail hold pressure??
Old Sep 12, 2001 | 10:43 PM
87tpi420's Avatar
mine is not.it goes up finally stays steady while pump is on and drops right off when you kill fuel pump. it is an aftermarket pump out of i dont know what but shouldnt it hold psi in the fuel rail?
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake hooker long tube headers mufflex 4"exhaust accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
Old Sep 13, 2001 | 03:38 AM
85 Berl's Avatar
I have only taken pressure reading on a '94 Ranger 4 cyl , but I believe it did hold pressure. In fact I'm sure of it because I had to relieve the pressure before I could take the guage off. There may be a check valve somewhere that is bad. I don't know that much about it. Hope that helped.
Old Sep 13, 2001 | 07:19 AM
mvftw's Avatar
Yes it should hold. I had the same problem, you have to plug up the return (smaller) line, test again, do not start car. Just turn key 'on' it should have what the pressure calls for. Turn key 'off', if it holds with the return plugged it's your fuel pump in your tank, if it drops again, it's your fuel regulator or leaky injectors.
Andrew6.688
Dec 13, 2015 10:59 AM
Sanjay
Aug 12, 2015 03:41 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
djmarch
Aug 9, 2015 05:27 PM
92projectcamaro
Aug 6, 2015 01:20 PM
