Replacing TV Cable..
Old Sep 13, 2001 | 04:19 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Ok, first, this is a newbie question.. so thanks for reading..
How to I replace my TV Cable, and does it require me to lift my car?
Third Gen Project
1989 305 tbi Camaro RS Red/Red
Ram Air II Hood
Centerline Champ 500 Rims
Edelbrock Open Element
MacEwen White Faced Guages
Old Sep 13, 2001 | 04:49 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Yes, you will need to raise your car to get to the tranny. The TV cable is attached to the tranny by 1 bolt. The TV cable to the tranny is located on the passenger side where the servo is located. Insure that when you replace it with a new one, that it has an O-ring. You may or may not have to lower the rear tranny to swap out the TV cable. Depends on how big your hand are. A good advice I can give is this, prior to removing the old TV cable, I would tie the bottom end of the new TV cable to the top end of the old cable. This way you can remove the old cable from underneath the car and at the same time you are snaking the new one in place. Hope this helps.
Old Sep 13, 2001 | 08:13 PM
Sonar_un's Avatar
Car: '86 T/A
Yeah, thanks for the help. I realized that I would need to drop the tranny to put a new one on, (Which is crap BTW), so I found just the end peice of the TV cable, which I needed to replace, and swaped it with a new one. Saved SO MUCH TIME... thanks anyway..
Third Gen Project
Ram Air II Hood
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
