Power door lock problem?
Old Sep 13, 2001 | 03:48 PM
89Firebird Formula350's Avatar
Ok i have an 89 Firebird Formula, and when i hit the button to lock the doors, the drivers side door doesn't lock. You can see that the little orange lock indicator on the side panel of the door is not going in all the way, thus i guess making it not lock. Do you guys have any idea what it could be, and would it be an easy fix?
Thanks a lot, i appreciate it!
Old Sep 13, 2001 | 03:54 PM
jasons86iroc's Avatar
what i did on mine was, shoot wd-40 in the door latch and then sit there and slide it back and forth untill it frees up. there is just gunk in there.
Old Sep 13, 2001 | 04:47 PM
firbird's Avatar
mine do that but i have to push the butten a few times to make it go all the way in
Old Sep 13, 2001 | 06:58 PM
tacoboy's Avatar
i replaced the switch itself on mine and it fixed the problem...3.50 or so from gm...might work...and its cheap if it doesnt work...good thing i only needed the drvr side one though cause the pssngr side one was discontinued...could always just flip it over i guess, and then black out the little pictures on the buttons...anyway im rambling...id check with gm though, its cheap
Old Sep 13, 2001 | 07:12 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Lol mine does the same exact thing to a T!
What do you mean by the door latch? I wanna try what you did.
1988 Jet Black IROC
5.7L W/ 64000 miles
Flowmaster Exhaust
Fully Loaded
My IROC In Readers Rides
My IROC
Old Sep 13, 2001 | 07:15 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
The WD-40 should do the job.
Later
Mike
Check out My Car Pics http://albums.photo.epson.com/j/Albu...667&a=13599419
Gran Turismo Americano "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
Old Sep 13, 2001 | 08:54 PM
Chevy83Z28's Avatar
My car has the same problem, I found a weird not fix but run-around. If only the drivers door is unlocked, it will have trouble locking. If you unlock both doors, it'll lock without a problem...
Try pressing the button down and holding it for a second (just don't burn up the relay, don't know if you can or not,) and see if the motor can retract the door lock any more.
Old Sep 14, 2001 | 10:51 AM
u r sofa king we tah did's Avatar
sounds more like a weak lock solenoid to me
Old Sep 14, 2001 | 11:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
This problem is common (years of grease and dust gum the works). Your best bet is to remove the door panel and thoroughly spray the mechanisms with WD-40 to free them up, then use a white lubrication. Do the same for the power-window tracks. You'll be surprised at how quickly and smoothly both windows and locks will function. Also while the door panel is off, cover the door-lock 'latch pieces' with an inch or so of vacuum tubing where they may knock/rattle against the door frame.
JamesC
Old Sep 14, 2001 | 02:39 PM
dbarkley's Avatar
Car: 1985 Trans Am
Transmission: 4spd auto
I'll chime in... Mine did the same thing. Armed the alarm system then I'd have to check to make sure the doors locked all the way. Hosed it down with WD40 and wiped it up and they work great now. Now I need to free up the power window linkage. I can time the window going up with a sundial!
1985 Trans Am - 305TPI AT
SLP Cat-Back - Welded subframe conns
misc engine mods
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackTopKing
Aug 19, 2015 12:13 PM
