CODE 15 AND 32!!!
Old Sep 13, 2001 | 06:03 PM
z28camaro396's Avatar
CODE 15 AND 32!!!
My car has been having idle problems, if i don't give it about 1500 rpm's for about a minute when i crank it, it dies. I got a code 15 and 32. I thought it could be a TPS or IAC sensor also but i got no codes on those. Code 15 is coolant related and 32 is a bunch of things...any helpful advice, anything i can do?
1988 305 TBI camaro. Flowmaster exhaust, K&N air filter, complete IROC-Z makeover (stripes, ground effects, interior...etc), kenwood c.d. player.
Old Sep 13, 2001 | 08:30 PM
Vader's Avatar
Nick,
A 32 is an MAP sensor problem on your particular car, and the 15 is an open circuit in the CTS sensor. Since the CTS is crucial in determining the fuel mixture and target idle speed, you really need to fix that first.
The MAP sensor could be related, it could be unplugged, it could have the vacuum line off, or may have failed.
Since you have both problems at once, you should also check all engine and chassis grounds, since the ECM references all signals to ground.
Later,
Vader
Justice and Freedom will Prevail
Old Sep 13, 2001 | 08:33 PM
Jza's Avatar
Jza
You idle depends heavily on the coolant temp. sensor. Check that out; make sure it's okay.
Old Sep 14, 2001 | 03:30 PM
OK...sorry for the stupid question following but where exactly is the CTS located on a LO3.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
