Cam Specs on LO3 Please...
Old Sep 14, 2001 | 10:50 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Does any one know the specs on the stock LO3 cam.. duration, and the valve lift ect.
I'm looking at changing cams, though I don't want something really hot.. Any recomendations. I also realize I'll need a new chip.. Would it be better to hook up with someone that burns em, or get an aftermarket one... Thanks
89 RS Camaro, LO3 305 TBI
Autometer Air/Fuel Ratio Guage
Cooling Fan Overide Switch
L69 Duel Snorkel Intake
Dynomax Ultra Flo SS Cat Back
Old Sep 14, 2001 | 11:23 PM
Jester's Avatar
So pathetically small..I blocked out out the exact specs..I can't recall them.
but anything is an improvment..I don't know of any aftermarket company that actually makes one smaller.
Old Sep 14, 2001 | 11:29 PM
Car: 89 Camaro RS
Engine: 305 TBI
So what dou think would be a good cam to go with.. ? I want to keep my stock springs, lifters ect..
Old Sep 14, 2001 | 11:45 PM
coach's Avatar
I believe these are the stock specs. for the LO3 (305ci,TBI,9.3:1CR):
Hydraulic Roller Camshaft
Lift: in.= .350
Lift: ex.= .384
Duration at .050
in.= 179
ex.= 194
Lobe Sep.
109.0
These are the numbers that I have written down. Can anybody confirm these numbers?
Old Sep 15, 2001 | 01:39 AM
Guest
Guest
Posts: n/a
Im sure the specs can be found through the main page, www.thirdgen.org
Go to the tech articles, look for camshaft stuff.
The specs above this look right. I'd just say its small/small .small/.small
or even puny/pathetic .gasp/.choke
Even the small crane compucam, which is like 204/214 .422/.443 (or close) would be much better, and thats still kinda small IMO. It would probably work just fine with the stock stuff though.
Old Sep 15, 2001 | 08:58 AM
Car: 89 Camaro RS
Engine: 305 TBI
Thanks Choach... I know you guys like the high end performance.. I do too, but since this is what I use as a dailing driver in the summer.. I don't want to much gas sucking performance.. a tank a week is good enough for me..
Jorlain
Oct 8, 2015 01:57 AM
ericjon262
Sep 11, 2015 06:07 PM
angel2794
Sep 8, 2015 06:22 PM
Formula_88AE
Sep 3, 2015 01:47 PM
masonta
Sep 1, 2015 06:40 PM
