Is this a good cam to go with? Opinons Please
Old Sep 15, 2001 | 10:18 AM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
I have a LO3, looking to put a better than stock cam. I have found a CraneCam for a TPI, would it be ok in a TBI? 500-400 RPM
Here are the specs.
Degrees Duration @ .050 Int./Exh. 184 204 (Stock is Int./Exh. 179 194)
Degree Lobe Separation 108 (Stock is 109)
Gross Lift Int./Exh. .384 .429 (Stock is Int./Exh. .350 .384)
Do you think it'll be ok to use with all my stock lifters, springs ect.. Would I need to change the ECM chip? Thanks
Old Sep 15, 2001 | 10:43 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
That looks like fairly stock replacement type cam by the specs.
If you really want a power inprovement over the stock cam you might want to look into a cam with 208in 214exh @.50. At least someting in the 200's @.50.
SSC
EDIT: Your ecm will work fine with any mild/mid cam. Your stock spring if they are in good condition will also work with a mild cam. Your should have a roller cam as your current stock setup. If I were you I would jusr replace the cam everthing eles should be fine unless your valve train is currently in need of work.
[This message has been edited by SSC (edited September 15, 2001).]
Old Sep 15, 2001 | 03:38 PM
Car: 89 Camaro RS
Engine: 305 TBI
Thanks SSC.. I'm happy to know my ECM will probably be good for mild hop-ups.. When I do the cam, I'll look at the rest of the valve train...
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
junkcltr
Aug 2, 2019 11:12 PM
camaro71633
Sep 1, 2015 10:24 AM
cstrobel65
Aug 15, 2015 10:19 AM
TreDeClaw
Aug 14, 2015 06:58 PM
