383 questions
Old Jun 30, 2005 | 09:31 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
383 questions
One of my friends neighbors offered me a 383 pretty cheap last night. I dont have all the specs for it but i know it is set up for a carb and has a victor Jr. intake, he said the motor originally came from a dually truck he said it has an rv cam. But he said if i try to convert it to tpi it will need different heads. So basically could this be true, would i be better off just using a big carb, if so would i lose a lot of low end torque? Maybe a newb post but i dont have much expierence with motor combos. Ill post more specs on the cam and heads ect when i get them.
Old Jun 30, 2005 | 09:49 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Are you sure its a 383? What heads are on there now, as in the casting number? What the block casting #?
Of course you can always do a cam swap. Probably don't want the victor jr. intake either.
Old Jun 30, 2005 | 09:51 AM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
Vic Jr. intake plus RV cam ?? The intake probably isn't the best choice for low end torque. The heads sound like the might be vortec heads? Find out what heads they are first then go from there. If they are, you could just get a vortec tpi base. Again, too many what ifs. Find out what you can, but I would think your first move would to get a better cam before you drop it in your car.
Old Jun 30, 2005 | 04:01 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Well he didnt build the motor a local shop did so he was kinda vague. But he does have a couple of high dollar motors in his cars, im gonna try to get some more info out of him ill post what i find. He did say it was out of an older truck and said there was a little money tied up in it he said it was a 383 but then said it was bored 60 over with a 400 crank. Wouldent that be a 388?
Old Jun 30, 2005 | 04:19 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
383 is just a generic term for a 4" bore block with a 3.75" stroke.
Don't pay too much for that engine, the block is all used up.
Old Jun 30, 2005 | 04:28 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
He said it was built then put in an s10 and ran for about 15,000 then he wrecked it.
Old Jun 30, 2005 | 10:33 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Being in something as little as a S10, he probably beat the **** out of that motor.
Do a leakdown test before you buy it, or atleast a compression test.
Old Jul 1, 2005 | 08:15 AM
CAH383's Avatar
Car: 86 Camaro Z28
Engine: 5.3 LM7
Transmission: TH400
I am not sure what you want the motor for exactly. But, if you want it for your car I would just use the engine that you have and stroke it. It's cheap enough anymore if you are just keeping it N/A. This way you will know what parts you actually have and it will all be new. Just my 2 cents
Old Jul 4, 2005 | 10:00 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
How much is he asking for it?
Old Jul 27, 2005 | 10:03 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
400.00 intake to oil pan
Cameeeero
Sep 18, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
