Stubborn flexplate bolts, need suggestions before I strip them....
Old Sep 15, 2001 | 03:52 PM
86IROC305's Avatar
I'm in the process of swaping my auto to a 5spd and everything was going smooth until I got to the last 4 flexplate bolts. I've been at them for a couple hours and I fear I might be starting to strip the heads because the ratchet keeps slipping off them, man these things are on there good! I need some quick suggestions on how I can get them out. I have some new bolts to replace them so I I'm not too worried about the old ones. Any suggestions will be greatly appriciated.
Thanks Joe
86 TPI 305 Iroc-Z
700R4 (rebuilt)
9 Bolt Rear Disc Swap w/ 3.45's
Accel HEI SuperCoil
Flowmaster
K&N Filters
Comp Cams 260H-12
212/212 444/444 @112lsa
Old Sep 15, 2001 | 06:19 PM
ede's Avatar
ede
not sure if i did it for the stock bolts or the 12 point arp bolts but i put a socket in my lathe to reduce the OD. it's a tight fit and removing a little metal makes a big differance. a grinder will work if you don't have a lathe.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Sep 15, 2001 | 06:21 PM
u r sofa king we tah did's Avatar
are you using a hex or a 12 point socket?
Old Sep 15, 2001 | 06:54 PM
86IROC305's Avatar
I was using my hex craftsman, but I have a cheapo 12 point I could try. My problem is that the edges are starting to round and when I try to put force on my ratchet it slips off at an angle. I managed to get one more out so there are only 3 left now, man what a pain. I'm tempted to use my dremel w/ a cutting disc and remove the heads, but I'm not sure how well that will work.
86 TPI 305 Iroc-Z
700R4 (rebuilt)
Accel HEI SuperCoil
Flowmaster
K&N Filters
Comp Cams 260H-12
Old Sep 15, 2001 | 08:12 PM
86IROC305's Avatar
ttt
Old Sep 15, 2001 | 09:10 PM
86IROC305's Avatar
Never mind, finally broke them loose. Took some WD-40, a hammer, and a breaker bar, but I got them! Thanks for the help though.
86 TPI 305 Iroc-Z
700R4 (rebuilt)
Accel HEI SuperCoil
Flowmaster
K&N Filters
Comp Cams 260H-12
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Cameeeero
Sep 18, 2015 04:00 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
