peddle easier to press when car off??
Old Sep 15, 2001 | 11:09 PM
breathment's Avatar
i noticed today, that while my car was off, and i pressed the gas peddle, it was really easy to push, alot easier to press then when the car is running. cause when the car is running its hard to keep it at a constant speed because of the peddle pressure. but car off, its realy smooth, does this have something to do with the TV cable connecting to the trany, and when the car is started then there is more tension on it?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
Old Sep 16, 2001 | 01:31 AM
Jza's Avatar
Jza
Engine vaccuum is holding the throttle blades shut. Once you break the "seal" the pedal is easily moved. If you're having a hard time holding a constant throttle position, try adding a helper spring. Just a regular old carb throttle spring attached somewhere on the motor to the throttle lever on whichever side makes it easier for you (spring either helps it open or helps it close so you have to push harder). You may or may not have to drill a small hole depending on what you hook the spring onto. I notice cars with hard pedals are easier to hold an exact position because you can put some muscle into it.
Old Sep 16, 2001 | 01:32 AM
Jza's Avatar
Jza
BTW, "pedal" is what you push with your foot. "peddle" means to sell something.
Old Sep 16, 2001 | 03:44 PM
Damon's Avatar
Totally normal. The throttle plates are offset on their shafts so that manifold vacuum and air flow apply a gently closing force to the throttle shaft. This is a safety feature and has been used for decades. It helps make sure that if the throttle cable snaps or the return sping lets go (like in an accident or just from old age) that the throttle CLOSES instead of staying open, possibly sending you on a wild ride.
[This message has been edited by Damon (edited September 16, 2001).]
customblackbird
Aug 15, 2021 10:16 PM
midge54
Sep 2, 2020 07:13 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
