Torque spec for engine mount to K member?
Old Jul 4, 2005 | 12:13 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
What is the recommended torque for the mount to the frame bolts?
I looked it up in the manual from Helms (GM), Haynes, and two small block rebuilding guides an couldn't find it any where. I tried searching here as well.
Old Jul 4, 2005 | 06:17 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
The torque should be pretty close to what it is for the motor mounts since it's a hardened bolt as well. I'd say to torque it to the 80 ft-lbs. listed for the engine mounting brakets in the Haynes manual in chapter 2 part c page 1.
Old Jul 4, 2005 | 06:20 PM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
isn't it only like about a 3/8s bolt????? i would say more like 30-40lbs
i bet 80 is for the big bolts that go through the engine and frame brackets
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
