blow by??
Old Sep 18, 2001 | 01:21 PM
92zeddar's Avatar
blow by??
I think my car has a bad case of blow by...
I took the oil cap off and the pcv valve out and revved it up and three was quite a noticable steam coming out... is this a correct test? or could it be a leak of antifreeze in the head gasket or intake because the car does you a little antfreeze...
92 z-28 G92 black with white racing stripes.
Dynomax cat back
Hypertech chip
5 speed
Old Sep 18, 2001 | 01:37 PM
Enkil's Avatar
If there was a head gasket problem there would either be oil in the radiator or antifreeze in the oil pan. You could check for that.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Sep 18, 2001 | 04:30 PM
89Irocz23's Avatar
hey I have a newly rebuilt engine and when I turn my engine off and take oil cap off I have steam coming out. Whats that mean?
Old Sep 18, 2001 | 06:18 PM
JETHROIROC's Avatar
Is it STEAM or SMOKE? Two very different things.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Sep 18, 2001 | 08:24 PM
89Irocz23's Avatar
to me it looks like steam, but its not a lot of it. im almost positive its steam unless its white smoke
Old Sep 18, 2001 | 08:30 PM
JETHROIROC's Avatar
Probably just oil vapors, I've seen my van do it but it's a Mitsubishi engine (Dodge). That's what the PCV system is for, so I wouldn't sweat it too much. The best test for blow-by is a compression test.
Old Sep 18, 2001 | 08:40 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
You really need to run a leak down test to determine if blow by is excessive. A compress test will work in a pinch.
blackz281le
Jan 11, 2016 07:51 AM
Fanatic1074
Oct 2, 2015 03:47 PM
86IROC112
Sep 28, 2015 08:17 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
90formulaVortec
Sep 3, 2015 09:26 AM
