clunks when hitting 80% of the time, etc..
Old Sep 18, 2001 | 04:16 PM
breathment's Avatar
EDIT: oops, clunks when hitting brakes, and since i can't edit\delete the topic title...
About 80% of the time when i hit my brakes i will hear a clunk coming from the front, (sounds like front right but not sure). Now the weird thing is that the sound doesn't happen immediatly after hitting the brakes, it depends. Sometimes i will hit the brakes and it will do it right away, other times i will hit the brakes and right before the car comes to a stop it makes the noise. or somtimes half way through it makes it. And it also made this clunk this morning when i was backing up. I was backing up a small hill out of my parking space, and i was turning at the same time, and it was idling back until i got steeper, so i gave it some gas to get it moving again, adn the wheel was turned, and i heard the clunk again. Its not a loud clunk, just loud enough to hear, most of my passengers don't seem to hear it. And i think i can feel it too, in the wheel and brake pedal. So before i take everything apart wut should i look for? wut might be making this sound??
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
[This message has been edited by breathment (edited September 18, 2001).]
Old Sep 18, 2001 | 05:18 PM
rezinn's Avatar
tranny mount
Old Sep 18, 2001 | 08:04 PM
breathment's Avatar
im pretty sure its not a tranny mount, its coming from the very front, no where near the tranny, something in the front suspension im pretty sure.
- David
Old Sep 18, 2001 | 08:27 PM
JETHROIROC's Avatar
Brake caliper noise would be my guess, mine does it too but the bolts are tight so the only thing I can think of is the pads shifting around in the calipers or the pistons sticking.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Sep 18, 2001 | 08:41 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Check your sway bar mounts at all four mounting points. Any one thats broken or if the bushing sqeezed out will cause a clunk.
Also pop the hood and pry off the plastic covers on top of the struts. Make sure these nuts are tightened down (They will still spin unless you hold the center stud, this is normal)
I've had front 'clunking' problems because of both of these happening. Hope this helps.
Old Sep 18, 2001 | 08:49 PM
rezinn's Avatar
My car did that, and I really thought it was an engine mount or something up front, but the sound went away when I replaced the tranny mount. If you've been racing or stopping hard, accelerating quickly, and still have the stock mount, or an old one, you should replace it.
BlueIroc-Z
Jun 9, 2019 03:22 AM
MY87LT
Aug 17, 2015 08:43 AM
zracTA
Interior Parts Wanted
Aug 15, 2015 12:10 PM
BlackBoulder
Aug 11, 2015 11:15 PM
MENINBLK
Aug 5, 2015 11:58 PM
