Cold Starting after doing ram-air intake
I guess the subject line doesn't describe very well what I'm asking. I am building a cold air/ram air intake today, the one where you move the signal lights. Anyway, I wasn't planning on reinstalling the part that throws heat from the exhaust manifold up to the snorkel. I don't know what it's called, but it's the piece with the flapper and the metallic looking hose. Has anyone done this? I figure you guys with open elements don't have it so it must not be too big a problem. I thought I might just be a bit worse off by drawing air from outside instead of the engine bay. Any help is greatly appreciated.
Car: Z28
Engine: Edelbrockified 305
Transmission: 700-R4
It probably should warm up slower without the little tube (don't know what it's called either). All I know is that I once had a 3/4 inch hole in the tube and when I replaced it it seemed to warm up alot faster.
Ludicrous Speed GO!!!
[This message has been edited by MartyMcFly (edited September 19, 2001).]
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
