383 crank question?
Old Jul 7, 2005 | 11:48 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
383 crank question?
I have a cast steel Eagle 383 crank w/one piece rear main seal and Im having a problem. Does the crank itself stick further out the rear main seal adapter than stock? Reason I ask is beacuse I did my 383 build up this winter and the pressure plate rubs my clutch fork on my T56. It did not on my 350 L98. I did check the T bolt and it is tight. I did buy a new T bolt and fork hoping that wear is the problem but I dont think it is. So I was thinking that my new 383 crank sticks out further than the 350's causing this "misalignment?" Anyone have this problem? I measured it at 3 10th's of a inch past the seal/one piece adapter. Is this about right? Anyone have there motor out right now that could measure it? Thanks in advance.
Old Jul 7, 2005 | 12:03 PM
Wayne's 383Iroc's Avatar
Car: 88 IROC
Engine: 383
I did not notice any diffrence on mine, the only diffrence should be the stroke. But mine is auto. I have my old L98 on the floor in the shop, I'll try to mesure it tonight.
Old Jul 7, 2005 | 08:35 PM
Randy92Z's Avatar
Engine: Miniram 383
Thanks Wayne, that will help me out alot!
Old Jul 8, 2005 | 05:43 PM
Car: 88 IROC
Engine: 383
From the adapter to the back of flywheel was about 7/32 with a tape measure. hope this helps
Old Jul 8, 2005 | 10:36 PM
Randy92Z's Avatar
Engine: Miniram 383
If were measuring the same thing, mine sicks out about 3/32 of an inch more than yours then, odd?
Caspar
Jun 19, 2016 11:19 PM
Mickeyruder
Sep 2, 2015 02:45 PM
lt1z350
Aug 28, 2015 05:57 AM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
