this is weird please help me!!
Old Sep 19, 2001 | 08:56 AM
89Irocz23's Avatar
ok its usaully when i turn I guess I hear this popping noise under me like near the tranny. I cant figure it out whenever I turn then give it gas I hear this pop pop not like real load but i can still hear it and feel it.
Old Sep 19, 2001 | 10:53 AM
lars92RS's Avatar
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
Tranny mount is prolly going bad.
-Lars
Old Sep 19, 2001 | 02:44 PM
89Irocz23's Avatar
if I dont change my tranny mount can I break anything else or can anything happen if I take it easy. I wont have time to change it til like saturday.
Old Sep 19, 2001 | 02:47 PM
Enkil's Avatar
I've gone for months without changing the tranny mount. I took it easy, so .. if you do the same you should be fine.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Sep 19, 2001 | 03:40 PM
rezinn's Avatar
It takes like 30 minutes to change, I think there are only about five bolts that need removing.
Old Sep 19, 2001 | 04:52 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Do you have a posi rear end?
If so, check your fluid, or change your fluid and add the GM Limited slip oil.
Bad Tranny mount should make a sound when you get on it and when it shifts, not when it turns, as far as I know.
I do know that when you don't have the limited slip additive in your rear end it wall make a metallic pop sound that sounds like it's coming from the tranny, but it's really coming from the rear end.
My little brother just had his gears replace and about 1/2 a day later it would pop when he turns from a standstill, adding the additive made it go away.
It's only $6.00 for a bottle from your local GM dealer.
Old Sep 19, 2001 | 05:33 PM
89Irocz23's Avatar
well when I hit the gas it pops too and sometimes when I turn.
Old Sep 19, 2001 | 07:06 PM
iroc5speed's Avatar
that is the tranny mount as mentioned above, that happened to me too. I took about an hour and a half to change when I didn't have a floor jack and stands. we just put it on the edge of the driveway where we could crawl under. make sure to support the tranny with a jack(we used the spare tire jack).We had to play with the bolts a little to get everything lined up right, that's what took so long.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
F-body-fan
May 4, 2026 09:42 AM
db057
Jan 10, 2020 08:55 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Marc Brown
Fabrication
17
Sep 25, 2015 03:43 PM
BWilcox
Sep 20, 2015 12:19 PM
