What dremel bits to use for porting & polishing heads?
Old Sep 20, 2001 | 03:32 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I just got a set of aluminum L98 heads for my IROC and figured I may as well do a little bit of mild porting to them.
What I was wanting to know is what dremel bits should I use to take the material away and what ones are best to polish it to a shine?
Any other tips are appreciated.
Thanks for the help
Robert
Old Sep 20, 2001 | 07:37 PM
ede's Avatar
ede
i use carbide tools fro my die grinders since i have a cheap source for them. for soft metal high speed steel bits would work ok. for aluminum you'll get better chip cleaning if you keep the tool lubed with wd-40 other wise it'll load up with chips.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
beastin91rs
Oct 9, 2015 07:38 AM
Dialed_In
Aug 20, 2015 01:45 PM
kah992
Aug 19, 2015 02:55 PM
86White_T/A305
Aug 17, 2015 12:16 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
