head
Old Jul 11, 2005 | 08:16 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
head
if a head gasket is bad could it cause engine knock and low oil pressure.
Old Jul 11, 2005 | 08:23 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
A engine with a failing head gasket may "knock" Specificly detonate, or sound like a bottom end knock if the motor is overheating. Won't generally cause low oil pressure.
Old Jul 11, 2005 | 08:28 PM
Car: 1987 iroc z
well thats probly what happend i overheated it started it back up and had a slight knock i know its not a rod or bearing and has some white smoke coming out of exuast. if everything goes right how long would it take to change headgaskets if everything goes smothley. thanks
Old Jul 13, 2005 | 09:12 PM
F-BIRD'88's Avatar
All day. In the driveway.
Old Jul 13, 2005 | 09:40 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
If you lost the head gasket you most likely warped or cracked the head or heads as well. Check them very carefully when you remove them. While they are off you might as well send them out for a valve job.
Old Jul 13, 2005 | 10:16 PM
Car: 1987 iroc z
well we pulled the heads off yesterday nothing wrong so it has to be in the bottom end. took about 3 hours to get everything unhooked and ready to pull probly tommaro i thought it would take alot longer than that. all the valvetrain look ok so cant wait ot find out what happend.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
