Is it my timing?
Old Jul 11, 2005 | 09:24 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Transmission: 4 Speed Manual
Is it my timing?
Recently when I start my car the rpms drop below idle (1000rpm) to around 500 then jumps back up. I usually give it gas to get it up so the car won't stall. Is this caused by a bad timing chain, or is it something else?
Old Jul 11, 2005 | 09:44 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Timing chain? Ehhh...dunno, put a timing light on it with the EST disconnected, and see if your base timing is walking around a bit.
The dip on startup....could be a few things. Done a tuneup recently? Check your plugs and wires,plugs may be a little old. Generally a dip like that is a 'rich dip'....either from getting too much fuel, or weak spark. But there's many many potential causes. Check the simple stuff first. After you give it more gas does it run better and smooth out, or try to drop again?
Old Jul 11, 2005 | 10:42 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Originally posted by Nixon1
Timing chain? Ehhh...dunno, put a timing light on it with the EST disconnected, and see if your base timing is walking around a bit...
Base timing is checked with the Set Timing Connector disconnected.
It's the connector coming out above the larger wire loom in the picture blow.
Disconnect it, start & hold the rpm steady, if the timing walks, check your chain, gears, and distributor, I'd start with the dizzy.
Old Jul 12, 2005 | 03:22 AM
sixpackmtrspts's Avatar
make sure your choke is working properly
Old Jul 12, 2005 | 12:50 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
How exactly does the chock work, I know I have an electronic one.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
