What woulda caused my alternator to start whining after 4 months of use??
Old Sep 21, 2001 | 12:35 PM
crazeinc's Avatar
Bought the alternator 4 months ago...starting to whine yesterday. Whine means it's going to die soon, correct?
The voltage has held steady thus far, but would it be a sudden drop off or a gradual death?
I don't understand why it would be whining already though. I know the belt wasn't too tight, but would a slipping belt cause damage?
This is on a normal v-belt setup...
Old Sep 21, 2001 | 12:42 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
A loose belt will cause the whining, just tighten as tight as possible, I usually get a long srewdriver and try to force it real tight.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Sep 21, 2001 | 12:44 PM
crazeinc's Avatar
well, that's what I thought, so I did that (forgot to mention it) and it didn't change anything...
it might have gotten wet during the huge storm here the other day, would that make any difference?
Old Sep 21, 2001 | 12:51 PM
crazeinc's Avatar
well, I thought about it, and it does get louder when I rev it...sounds kinda like a belt problem huh? I need a new belt anyways.
Old Sep 21, 2001 | 12:52 PM
Biochem's Avatar
Car: 2002 SOM z28
Yeah, a wet belt, or if you touch it with greesy fingers will make a belt whine for a while. Changes in temp will also make a belt loosen up sometimes.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Sep 21, 2001 | 01:12 PM
crazeinc's Avatar
and I imagine a worn-out belt would cause it to squeak to...
Old Sep 21, 2001 | 03:54 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Or the bearings could be shot. I'd have to hear the whine to tell.
WS6 Trans Am.
View My Ride @ thirdgen.org
Old Sep 21, 2001 | 04:00 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If it starts throwing sparks, it's not the belt. (Yep, had that happen... "What's that whine? Sounds like the alternator!" Well, I popped the hood, and it was definately the bearings.)
-Tom P (Hot rodded 1986 Firebird 2.8l)
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
