fuel pressure a NON steady 44 psi, PLUS Injectors are clicking loudly
Old Sep 22, 2001 | 09:55 PM
breathment's Avatar
ok, i finaly brought my fuel pressure tester !!!! and i hooked it up, disconnected the vacum hose going to regulator, and with the car warmed up, it was 44 PSI, however, the needle was jerking back and forth about 1PSI or maybe less. and it was a constant jerking, kinda looked like a vacum guage on a engine with bad valves or something. what could be causing this.
also isn't 44 PSI about 2 or 3 PSI low?
and also.. the injectors are ALL ticking, kinda loud, and you can put your finger on them and feel them also, so its not the rockers. what all is wrong?
thanks!!
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
Old Sep 23, 2001 | 08:44 AM
Vader's Avatar
David,
First, the fuel pressure specifications that I have are 37 PSIG ±3 at idle, and 44 PSIG ±3 with the vacuum line disconnected.
The fuel pressure fluctuation is a different matter, and may indicate a regulator that is sluggish, a sticky pump discharge valve, or an injector that is flowing excessively. The minimal difference is probably not a big concern, however. There is going to be a minor pressure fluctuation every time an injector bank opens, and you may just have an especially sensitive gauge.
As for the injectors clicking, I'd be concerned if mine didn't. The valve pintles are opening and closing rapidly, and that sharp clicking indicates that they are not sluggish in operation, but are being very compliant.
Later,
Vader
Justice and Freedom will Prevail
9192camaro
16
Feb 3, 2019 12:21 AM
Infested
May 22, 2018 11:56 PM
pimp2303
Jul 27, 2017 02:03 PM
mdtoren
Aug 23, 2015 12:52 PM
Kaweh
Aug 9, 2015 02:54 PM
