Starter shimming procedure for PG260 starters?
Old Sep 23, 2001 | 02:34 PM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
I have just replaced the old heavy GM starter on my 89 IROC with a newer lightweight PG260 model. I am trying to establish the proper tooth engagement distance to the flywheel. The instructions for my old starter called for using a 1/8 inch diameter pin (drill bit) to check the distance from the flywheel teeth to the starter pinion shaft. The new starter has a pinion shaft with a much different diameter from the old one, and with no shims in place it looks like I have about 1/4 inch of clearance on this one.
Does anyone know the proper shimming procedure for setting the clearance on the newer PG260 starters? I believe they were used on the fourth gen F-bodies.
89 IROC with lots o' stuff
-=ICON Motorsports=-
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
gord327
Oct 3, 2015 01:25 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
