Deburring Question
Old Jul 15, 2005 | 03:30 PM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Deburring Question
Just a quick question on deburring. Below is a pic of my new timing chain cam sprocket. You can clearly see left over burs on the outer edge of 2 cam bolt holes. I'm kinda mad that quality control didn't catch this & clean it up before they boxed it, but maybe I'm just **** about these things! Anyways, what would be the safest method of cleaning this up. I was going to use a triangle file to scrap it but I want to check with other peoples opinions also. Thanks!
Anthony
Old Jul 15, 2005 | 03:31 PM
Car: 89 RS
Here's a pic of the other side too.
Old Jul 15, 2005 | 05:22 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
There are "deburring tools" available, look like a crooked file...would work easily in the first pic, 2nd pic might be difficult to keep frmo whacking into the lip on the sprocket....so I'd opt for a round or moon fine file...not one with a edge (flat/square/triangle, etc) to keep from gouging.
I hate stuff like that too...a machined part that needs finishing work on it. But I would remove the excess...to ensure even torque on all the fasteners.
Old Jul 15, 2005 | 06:03 PM
Car: 89 RS
Hey thanks for the suggestions 8Mike9! Here's a pic of the triangle file I was gonna use. I might go with your suggestion of a round fine file for the other side though.
Old Jul 15, 2005 | 06:08 PM
laiky's Avatar
i always use a drill bit that is larger than the hole
Old Jul 15, 2005 | 07:56 PM
Car: 89 RS
Cool. I never thought of that one. Thanks!
Old Jul 15, 2005 | 08:44 PM
Vader's Avatar
You could also use a rotary deburring bit, either a rosebud or spherical. They're about $7. If you're only doing a few holes, a larger drill will be fine, so long as you control the depth.
Old Jul 15, 2005 | 08:51 PM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
bigger drill or countersink works well. was that part made overseas? I see alot of oversea's parts that they take no time to deburr. Not deburring realy sucks when you cut your self on the burrs like i did on a recent wheel barrel while assembiling.
Old Jul 15, 2005 | 09:09 PM
Car: 89 RS
I got it straight from Comp Cams. The box says "American Made".....but when I looked on the link chain itself guess what I found....."Japan"! I guess they outsource sometimes huh lol!
Thanks for everyone's suggestions. It's a minor thing but many of you jumped right on it to give me some help. These boards rock
Old Jul 15, 2005 | 10:11 PM
laiky's Avatar
when using the bit to deburr, do it by hand not with a drill
Old Jul 16, 2005 | 07:39 AM
Car: 89 RS
Kinda figured Thanks!
fasteddi
Sep 10, 2015 09:32 AM
gixxer92
Sep 1, 2015 04:32 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
