Anyone Have a Street&Performance custom Prom?
Old Jan 12, 2001 | 04:54 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
If so how did it work for you? I just ordered one...IM hopeing that it will be a good base line for tuning the car.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Jan 12, 2001 | 05:24 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I have one in my 89RSconvtZZ4TPI. I have no complaints, feels a little better than my stock L98 chip did, solved a few idle problems I was having.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Jan 12, 2001 | 05:42 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Hey Rob...are you using 22# or 24# injectors? Did they send you a spec sheet on where to set the idle/Timing? I heard they build alot of street rod stuff. That is all custom chip work,They should know what there doing. I also deleted the EGR,It was only 185.00 for the chip.
Old Sep 23, 2001 | 07:50 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
It was a good cost effective custom prom for starters. I don't believe you can read it though to see what they changed or change something yourself. They encrypt it somehow.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Sep 23, 2001 | 12:54 PM
DJdude's Avatar
I have that chip and love it , it smoothed my shifts alittle and now my car will accelerate till it blows up. Sorry but the day my speed limiter kicked in is that day i started looking for a chip, that was the most depressing feeling, your engine screaming and then it just quits. oh well
I live life a quarter mile at a time eatin fords and ****tin ricers
Old Sep 23, 2001 | 08:15 PM
Rob P's Avatar
Engine: ZZ4TPI
I have #24 SVO injectors. Bernard tried to get into the chip but no dice. Wonder if anyone on the prom board has had luck with these chips? And no, S&P does not provide any data sheet. I suspect they just played with the timing a little.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
dusterbd
Sep 29, 2015 08:40 AM
