Oil additives
Old Sep 22, 2001 | 08:30 PM
Vomex's Avatar
Oil additives
I was wondering if anyone knew if oit additives had any negative effect on an engine? I have an 89 GTA and it has a minor oil leak like most cars that age do. I was thinking about using one of those oil additives that helps seal leaks, but obviously that additive is not motor oil and i was curious if you could cause any damage using it.
Old Sep 22, 2001 | 08:45 PM
BrianB's Avatar
Chances are they won't help a leak, the additives are mostly used to try and help seal valve stems up to quit burning oil. Where is your leak coming from?
Old Sep 22, 2001 | 09:12 PM
Vomex's Avatar
i really cant tell where the leak is coming from, oil and dirt have blown around down there and it makes it tought to tell. Could be the rear main seal but im really not sure. Is there any good way to clean under there to get a better look?
Old Sep 22, 2001 | 09:13 PM
breathment's Avatar
wut kind of oil are you using now?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
Old Sep 23, 2001 | 04:37 PM
Vomex's Avatar
Valvoline 10w-30. Should i be using another kind?
Later,
Vomex
'89 GTA 5.7l TPI
Old Sep 24, 2001 | 09:48 PM
breathment's Avatar
you might wanna get some brake parts cleaner or any type of degreaser to get down there and spray that area off really good, and maybe even use some type of brush to get all the heavy deposits off, and remember that sometimes oil will be blown to another part of the engine while drivign making you think that oil is leaking from one place when actualy it is leaking somewhere else.
and ya have mail
- David
Old Sep 24, 2001 | 10:15 PM
88 GTA Notchback's Avatar
Vomex,
You may want to use 20W-50 in your car. Thats what I use in mine and I noticed an improvement with my leaky valve stem seals (I replied to your other post). I also noticed better oil pressure. From what I have heard, don't use any oil additives. They can really **** your engine up.
88 GTA Notchback
A4 / 350
Stock
** New User Name**
Kill List:
95 Mustang GT |88 Mustang GT
94? Impala (real close)|97 Dodge Neon
86 Corvette |2000 Prowler
88 ASC GTA | And a few more Accords and Neon's.
And more Civic's then I can count. Why do they even bother?
Hotrodboba400
Dec 10, 2019 07:07 PM
PurelyPMD
May 5, 2016 04:57 PM
tyeo098
Nov 30, 2015 06:27 PM
CatmanFS
Sep 19, 2015 09:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
