SERIOUSE HELP PLEASE !!!!!!!!!
Old Sep 24, 2001 | 10:28 PM
91firebirdfosho's Avatar
Car: 1991 firebird formula
Engine: 383
Transmission: th350
Axle/Gears: 3:73 posi
i have a 91 305 tbi i have a hypertech chip i just put a edelbrock cam in 194 214 at .050 lift i went from a roller to a hydrolic i put on pacesetter headers on along with a edelbrock prformer intake for the tbi we put all on and i beleive the timing is at 6 or eight degrees TDC when i drive it it feels as if it has no power when i drop it from park to drive the rpms drop really low and the car shakes. its got a speratic idle but not really rough all the time. It accelerates slower than it used to and it worries me. Its too much money to spend and not have it work right. DOES THE TIMING NEED TO BE ADVANCED DOES THE FUEL PSI NEED TO BE CHANGED OR EVEN BIGGER INJECTORS remember the car doesnt feel as if it has get up power. weird idle and no throttle response
Old Sep 24, 2001 | 10:34 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Are you sure the firing order is correct?...I always switch 5 and 7..heh
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Sep 24, 2001 | 11:00 PM
SHE DVL's Avatar
I have a friend that did the same thing with his car: went from a roller cam to a hydraulic cam. And it ran like poop. From his experience, and what I've heard from others, you shouldn't change from a roller cam to a hydraulic if you're gonna use the stock computer chip. And a Hypertech is close enough to stock since it's also designed for a roller cam. I guess there's a big difference between the two types of cams as far as vacuum goes, and it confuses the computer. It's just a possibility to consider.
Also, when you converted it to hydraulic did you change the lifters and pushrods? They're both different between the two cam types.
Michelle
92 Formula 350
91 Z28
Old Sep 24, 2001 | 11:26 PM
Engine: 383
Transmission: th350
we put the different lifters in and different pushrods that a pontiac book said to do ,,it said it should run fine with the different rods
Linson
Oct 24, 2025 02:00 PM
ZEEYAA
Apr 16, 2023 08:29 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
grngryoutmyway
Oct 18, 2016 05:48 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
