Stupid M/C Solenoid
Old Sep 25, 2001 | 08:27 AM
MartyMcFly's Avatar
Car: Z28
Engine: Edelbrockified 305
Transmission: 700-R4
Stupid M/C Solenoid
Here's the deal: Check Engine light comes on one day, so I take a quick look under the hood, and the Mixture Control Solenoid is somehow unhooked. When I reconnect it, the motor dies after 20 or so seconds. I know that the ECM will quit pulsing the M/C solenoid if it gets no signal from the distributer, but all the wires going both from the ECM and to the distributer are connected. Car runs fine with the M/C disconnected, but this morning it was in the low 40's (by far the coldest it's been since this whole episode occurred) and the motor ran pretty ruff until warm - which can be attributed to the M/C not being able to richen the mixture--right?
Ludicrous Speed GO!!!
Speed Trap Exchange
[This message has been edited by MartyMcFly (edited September 25, 2001).]
Old Sep 25, 2001 | 10:28 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
You've got things all mixed up. With the MCS unplugged it defaults to a ridiculously rich setting, richer than WOT rich.
You're chasing demons, there could be many things going on with your car, but one thing that is for sure is something is wrong if it runs better w/ the MCS disconnected. I'd vote for vacuum leaks (probably a lot of 'em) and perhaps a timing or VAC sensor problem. Until you can rule those out, i'm sticking with that...
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
305 TPI A4 2.73 - 14.8 @ 93.1
Stock except ported plenum and dual cats
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Quzyle
Oct 15, 2015 03:35 PM
djmarch
Oct 2, 2015 10:41 PM
83ho87gn
Sep 26, 2015 08:49 PM
spartanreaper
Sep 25, 2015 07:22 PM
83ho87gn
Sep 24, 2015 08:58 AM
