Quick LT4 HOT cam question
Alright i've got an 89 350 TPI out of the car and it's going in very soon. And a while back I ordered an LT4 HOT cam to put in it. My only question is since the heads aren't coming off what do I need to have this cam work in my car? I have no idea what rockers would be best or springs i need to get. I heard someone tell me 1.6 rockers might cause the valve to stab the piston which is no good hehe. I just want to get the cam in and I need to do it quick since this guy is trying to finish this job ASAP.
By the way its an all stock motor. Thanks for replies!
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You will need new springs, and you will need to have the heads machined to accept a cam with that much lift. I think you just need to cut down the valve guides so the retainers wont hit. Your mechanic should know this stuff. The cam has a lift of .492"/.492" with 1.5 rockers.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
1988iroc350tpi
Aug 14, 2015 07:52 PM
