what timing?
Old Jul 19, 2005 | 07:17 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
what timing?
what would be a good set to put the timing at on a 91 305? it has headers and a full exhaust, open element.?
Old Jul 19, 2005 | 10:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
2 degrees more base timing than it has now. Repeat after test drives until you get pinging (knocks). Then back it off 2 degrees.
Old Jul 19, 2005 | 11:13 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
what grade fuel, if you have 93 in the tank and advance the timing then drop in 87 you will have serious pinging and overheating problems. and what 5-7kid said will work well, if you run 93 try 8-10* base timing and advance/retard from there.
Old Jul 21, 2005 | 08:53 AM
ok thank you
Old Jul 21, 2005 | 01:42 PM
well one more question... to advance the timing.. would i turn the dist. clock wise or counter-clock wise? i know it is a stupid question, but i have to leanr some how..
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
