crankshaft pulley removal
Old Sep 25, 2001 | 02:26 PM
rag93vette's Avatar
trying to remove crankshaft pulley to replace harmonic balancer and everytime i try to get it loose it turns. thanks for any help anyone can give.
Old Sep 25, 2001 | 05:58 PM
ede's Avatar
ede
an impact wrench makes the job easy. you can also hold the pulley or belt to try to stop if from turnning. if that doesn't work you may have to stop the flywheel/flexplate from turnning.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Sep 25, 2001 | 07:27 PM
JETHROIROC's Avatar
Just put the car on ramps, leave the spark plugs in, and grab that sucker with one hand while you remove the bolt easily with a 1/2" breaker bar in the other. It also helps immensely to leave the belt on while you do it. The hard part is holding the pulley while you torque the crank bolt back to spec . Trust me, this is an easy job, I just did it last month. Focus your bowtie power.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Sep 25, 2001 | 10:30 PM
KNTA4DNU's Avatar
Car: '97 Z28
Engine: 5.7
Transmission: M6
Try putting a wrench on one of the small outer bolts and hold onto that while you back out the center bolt. Worked for me, but I would imagine it's possible to break off the smaller bolt if the center one is REALLY tight.
Old Sep 26, 2001 | 12:35 AM
rag93vette's Avatar
the 1/2in breaker bar did wonders! got it all off this evening. i never even had to hold the pulley. so tomorrow i will try out this balancer installation tool and put it all back together and hope it works. the balancer was in bad shape it had separated and the outer part was rubbing on the timing chain cover. need to get this running again while i fix the vette. thanks for the help!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
