Full Throttle
Old Jul 19, 2005 | 09:40 PM
formula1988's Avatar
Car: 1988 forumla 350
Engine: l98 350 tpi
Transmission: 700r4 2100 stall
Full Throttle
I am have a shifting problem.
-The car shifts fine driving it normal
-wont shift into third when the car is at full throttle.
-I tried to adjust the throttle valve cable and i still have the same problem.
Old Jul 19, 2005 | 10:21 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Are you sure it 3rd and not 4th. Because they will not shift into 4th (OD) at WOT.
Old Jul 19, 2005 | 11:51 PM
Lunatic0987's Avatar
Car: 89 Formula 350
Engine: 355
I have this same exact problem..I would always have to let off cause the car wont shift. I thought it was 3rd also, but it might be 4th. But why wont it shift? And how can i fix this, just take it out of OD?
Old Jul 19, 2005 | 11:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
GM designed it to not shift into O/D at WOT, to save the clutches. O/D is for cruising, not accelerating. You can make a change in the valvebody to let it hold O/D at something like 80% throttle, but why do you need to?
Old Jul 20, 2005 | 08:15 PM
Engine: l98 350 tpi
It is third gear.
When i put it to the floor it will not shift into 3rd.
sometimes it will shift but it takes a while and i loose speed.
It shifts just fine when im driving it normal.
i dont think it is the over drive.
Old Jul 20, 2005 | 09:30 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
How fast are you going and what are the rpm's when this is happening?
I'm still betting its OD.
Old Jul 21, 2005 | 09:00 PM
Engine: l98 350 tpi
From a dead stop.
The rpms sometimes dont stop i have to let off. If i get lucky it will stay at 5200 for a second or two and shift.
I just put a pulley set on.
When i had my headers done they took out my air system and one of the pulleys
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
GouldyGTR
Sep 7, 2015 09:05 PM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
