Battery or alt.?
Old Sep 26, 2001 | 09:06 AM
fiveironfrenzy's Avatar
Battery or alt.?
I've got an 86 IROC Z28 305. Took the kids to school and came home. When I got ready to leave 30 minutes later car was dead. I hooked up a charger to it and 45 minutes later it started. Drove into town but the gauge for the batt. never made it to the half way point, in fact the more I drove the needle kept going down, to the point that when I would put on the brakes the radio would go off.
Is the a bad battery or bad alternator?
Old Sep 26, 2001 | 09:08 AM
Jester's Avatar
Alternator probably.
Old Sep 26, 2001 | 11:07 AM
82camaro's Avatar
Car: 82 camaro SC
Probably the alternator. Check the battery--a weak battery can overwork the alternator and break it.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Sep 26, 2001 | 02:01 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
At this point it's probably both. Once you kill a battery driving with a dead alternator, the battery will prolly be bad enough to kill your next alternator too. Try charging it up to make sure, if you fan get a full charge on it then you are OK. Just a head s up thats all.
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
drumstixer
Sep 29, 2015 03:02 PM
