Proven CAM for this set-up
Old Jul 21, 2005 | 10:51 PM
IroczInOz's Avatar
stealth ram
modified transam air indiction k and n screens removed
stock throttle body (this weekend i am boring and fitting bigger blades ) hope to get it out to 55mm
pro comp dizzie with amplifier stock computer i only have 305 chip
33 pound inject from as new injectors really cheap but good
air flow dynamics heads 64 cc 195 ,s 1.6 rockers crane
350 4 bolt block sleeved 30 tho over with 10.5 trw forged pistons moly gapless ring
NO CAM YET NEED ADVICE would like 560 thou lift as it will rev to7000 with stealth
custom headers into 3 inch single no cat straight through 3 inch muffler
turbo 700 3300 stall supposed to be dominater but colour different?
stock 3. 3 gears does 16-1700 in over drive at 100 k,s
2 vl fuel pumps with surge tank (in tank pumps suck)
Shooting for 11's What CAM to put in?
I posted this in the prom forum too as I am asking has anyone got a similar set-up to get a copy of your chip top get a baseline to work from. Stock ECM.
Will MAF be problem in the 500hp+ range?
Old Jul 21, 2005 | 11:04 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
I dont think the stock maf will flow enough, look into a tuneable one. That will help ,and your gonna need a prom to control your injectors. Got me on a camshaft for that beast, may wanna just pick up a new tb, just dont oversize it i know the stock one flows 650cfm so divide that by 46mm? and times it by 55mm to get your tb cfm, have fun with that engine..
Old Jul 21, 2005 | 11:06 PM
IroczInOz's Avatar
Either tunable MAF or go with MAP? I wish this was my engine but it is a friends and he is trying to get some advice on the CAM
One day I hope will be my turn
Old Jul 22, 2005 | 12:34 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Look into the new Comp Cams XFI (extreme fuel injection) line, they are right up your alley.
Old Jul 22, 2005 | 06:11 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
make life easy and go with a tuneable Maf if its a maf car
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
64goatman
Sep 9, 2015 01:09 PM
Strick1
Sep 4, 2015 07:11 AM
