what to do to a 305 (besides paxton)
If anyone could give me a list of things to put in a 92 305 to make it about 300/325 horse it would muchly be appreciated or is it not possible...
92 z-28 G92 black with white racing stripes.
Dynomax cat back
Hypertech chip
5 speed
Dynomax cat back
Hypertech chip
5 speed
Heads and cam alone can get you there with your G92 car. Just start with all the bolt on's and move on to heads and cam when you finish that off. You'll be where you want. Good luck!
I am looking to buy Edelbrock T.E.S. headers with the y-pipe. I am also looking for a 3.42 - 3.55 posi disc rear. cheesy@fred.net is my e-mail, send a letter if you can help!
- Red '88 IROC 305 TPI T-5 w/3.08
- Accel 300+ Ignition
- Accel 300+ Pro Sleeve Plug Wires
- AC Delco Rapid Fire Plugs
- Dual Friction Stage III Centerforce Clutch
- Energy Suspension Transmission Mount
- Flowmaster Force II 3 Chamber Cat Back Exhaust
- Gutted Airboxes
- Hypertech Stage II PROM
- Hypertech Airfoil
- Throttle Body Coolant Bypass
- Best Maryland (40 degrees) E/T 14.686, 60' 2.205, 1/8th mile 9.461, 1/4 mile MPH 93.91
- Best Florida (80 degrees) E/T 14.88, 60' 2.163, 1/8th mile 9.540, 1/4 mile MPH 92.74
- Best 60' 2.163(Florida)
- TPiS AFPR set to 42psi using Accel Fuel Pressure Gauge (Installed after Maryland run)
- Aluminum Driveshaft (Installed after Maryland run)
Transmission: 4L80E/4L80E
See sig. Cam, heads, exhaust a must.
If you stay TPI, you'll have to at least port the plenum and spend some money on runners and the like (stock won't cut it).
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
