Bronze dist. gear needed?
Old Sep 28, 2001 | 12:15 AM
88TAJeff's Avatar
Car: 88 T/A
My car had 130,000 Km on it when I swapped cams. I plan to replace the dist. gear ( the timing is jumping around 2-3 deg). Do I replace it with the stock one or do I use a bronze gear?
Thanks,
Jeff
88 Trans Am 305 Auto Red/Silver, MSD coil,wires, ported plenum, gutted airbox, TB bypass, comp cams 08-408-8, everything else stock
Old Sep 28, 2001 | 02:26 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Stock. They use a standard iron distrib gear on the stock roller cams. Only aftermarket billet cams need the bronze or mellonized gear. The factory rollers are cast steel.
BTW, it's a borg warner part if the parts guy needs help (it took me awhile waiting...) about $25 or so.
[This message has been edited by JoelOl75 (edited September 28, 2001).]
Old Sep 28, 2001 | 06:16 AM
IROC&ROLL
Guest
Posts: n/a
Joel, he does not have a stock roller cam; check his signature, he's running a CompCam.
Jeff, the instructions with your cam should have indicated if you need to use a bronze distributer gear. You should give CompCams a call (1-800-999-0853) and ask them to be certain. If a bronze gear is required, using an iron gear will cause rapid wear on your cam's gear. However, if not required, you don't want to use one as bronze gears wear much more rapidly than iron gears. It seems I was told they require replacement about every 15-20,000 miles.
Old Sep 28, 2001 | 06:43 AM
ede's Avatar
ede
as you were told, if it's an aftermarket billet cam you need the bronze gear.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Sep 28, 2001 | 07:49 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
comp cams hydrollers are ground using a special core. Its called austempered and it does not need a bronze gear.
Old Sep 28, 2001 | 09:12 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
All of the Comp hydraulic roller cams I've ever run, including the one in my car right now, have the stock dist gear, and work just fine.
ICON Motorsports
Old Sep 28, 2001 | 10:17 AM
88TAJeff's Avatar
Car: 88 T/A
Thanks for your replies. I called Comp cams this morning and they say I can use the stock gear.
apo_bailon15
Mar 28, 2016 05:20 AM
IROCZ1989
Jan 24, 2016 03:55 PM
db057
Aug 22, 2015 08:17 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
