the 5.0 vs 5.7 question but stock vs stock
Old Sep 26, 2001 | 08:40 PM
camaro6spd's Avatar
Ok in 1987 you could get the 5.7 which had 220 hp and you could get the 5.0 with a 5 speed(mine) and get the HO cam(l98 cam??) and get 215, now wouldn't that mean that the 5.0 could keep up with if not pass teh 5.7 seeing that it is a 5speed? anyway, what did the 5.7s run then and what did teh 5.0 run then? anyone?
Old Sep 26, 2001 | 08:48 PM
82camaro's Avatar
Car: 82 camaro SC
Your looking at peak HP. What about the peak torque. What about the power (hp and torque) under the curve.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Sep 26, 2001 | 09:42 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Your also looking at auto Vrs standard. Sticks put more power to the pavment than autos. But still, I see where your comming from Id say if you had a 3:42posi and the 220 hp auto 350 had 3:08's or 2:73's I'd think you would probably walk all over the 350.
SSC
Old Sep 27, 2001 | 10:20 AM
highhat's Avatar
I have an 89 auto 350 IROC 230 advertised bhp
2.77 gears. I raced an 88 IROC 5 speed 305 don't know what his bhp rating was but He didn't stand a chance from the word go. My car is stock the only mod i've done is remove the smog pump. I'm no expert but more displacement = more torque and hp is relative to torque.
Blue 1989 IROC Z28
Old Sep 27, 2001 | 12:21 PM
Drakar's Avatar
Also to add a note GM ALWAYS underrates there cars to prevent insurance and dis-satisfied customers that dyno there car at 1hp less then advertised. Also nothing could be rated over the Corvette but we all know the 89 TTA did not have 250 horse and drop a 13~ or so 1/4 mile.
1989 Trans Am GTA, L98 5.7L TPI, TH700-R4, T-Tops, dual cats, 9-bolt rear, 3.27,
- K&N Air Filter
- Dynomax muffler
1992 Camaro RS, LO3 5.0L TBI, T-5, T-Tops, 3.08, L69 Dual Snorkel - Sold
- K&N Air Filter
Honda engines ROCK, I have one on my lawn mower but I still have to push it.
Old Sep 27, 2001 | 02:02 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
That is the type of stuff I hear ricers say all the time.
*****: "Your IROC has 240hp stock and my Type-R/VTech (or whatever the hell it is) has 220hp. I can beat you!"
My reply: "NO YOU CAN'T!!! While hp numbers are similar, I am putting out almost 350ft/lbs of torque vs. your 175!!! You don't stand a chance!"
Horsepower NEVER, I repeat, NEVER, tells the whole story.
1989 Chevrolet Camaro IROC-Z
L98 - 350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back, SLP 1 5/8 Coated Headers, 3.23 Posi rear, Hypertech chip with 160stat, MSD 6A, Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, !TB Coolant, Spohn Dual Cat SubFrame Connectors, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's, Accell 24# injectors
1989 Chevrolet Celebrity Eurosport <--DEAD AS OF 9/20/01
2.8 MPFI, no mods
225,000 miles and still ticking!
More info and pics on my webpage:http://go.to/iroc-z
AOL IMer: GPA 0point0
Old Sep 27, 2001 | 10:11 PM
Yarnboy's Avatar
I have taken EVERY stock/slightly modded 350 MAF car I have ever raced. At least by 2 car's @ 95mph. I have no reason to lie. It get's annoying when people under estimate 5 speed LB9's.
  • Red '88 IROC 305 TPI T-5 w/3.08
  • Accel 300+ Ignition
  • Accel 300+ Pro Sleeve Plug Wires
  • AC Delco Rapid Fire Plugs
  • Dual Friction Stage III Centerforce Clutch
  • Energy Suspension Transmission Mount
  • Flowmaster Force II 3 Chamber Cat Back Exhaust
  • Gutted Airboxes
  • Hypertech Stage II PROM
  • Hypertech Airfoil
  • Throttle Body Coolant Bypass
  • Best Maryland (40 degrees) E/T 14.686, 60' 2.205, 1/8th mile 9.461, 1/4 mile MPH 93.91
  • Best Florida (80 degrees) E/T 14.88, 60' 2.163, 1/8th mile 9.540, 1/4 mile MPH 92.74
  • Best 60' 2.163(Florida)
  • TPiS AFPR set to 42psi using Accel Fuel Pressure Gauge (Installed after Maryland run)
  • Aluminum Driveshaft (Installed after Maryland run)
I am looking for a 3.42 - 3.55 posi disc rear. cheesy@fred.net is my e-mail, send a letter if you can help!
Old Sep 28, 2001 | 09:12 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Nothing against 5 speed LB9's, but I have beaten a few of them with my 89 5.7. Hey maybe they just didn't know how to drive. They all run good man 5.0's & 5.7's.
later man
Mike
Check out My Car Pics http://albums.photo.epson.com/j/Albu...667&a=13599419
Gran Turismo Americano "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
Old Sep 28, 2001 | 09:35 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
West is about right.... a properly driven 83 or 84 L69 5-speed, a LB9 5-speed (especially a S-D one) and a L98 auto all in bone stock condition all run real close to 15 flat. To compare the factory's HP & torque numbers is more than a little misleading. Those 3 setups are the fastest of the 3rd gens. They are close enough that the driver, tires, other options in the cars (weight!!!), and stuff like that could tip the balance in favor of any one of them. This is true especially if the 305 is a Camaro and the 350 is a Firebird, since on average the Pontiacs tend to be a little heavier.
ICON Motorsports
Old Sep 28, 2001 | 11:17 PM
whiteroc's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Yarnboy:
</font>
Not this slightly modded MAF 350. See sig.
I have beaten modded LB9 5 speed cars with 3.73 gears with my 2.77 geared IROC. 350 Torque is KING.
89 IROC-Z 5.7L 2.77 GEARS
130,000 MILES
ALL FREE MODS
K&Ns FILTERS
FLOWMASTER MUFFLER
PERFORMANCE RESOURCE CHIP
AFPR & PORTED PLENUM
Best 1/4 E.T. 14.09 @ 97.2 MPH
Best 1/8 E.T. 9.09 @ 77.4 MPH
Best 60ft. 2.03
Old Sep 29, 2001 | 12:07 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
stock vs. stock the 5.7 car puts out better numbers. all the way through the tests i have from the third gen years the 5.7 was about 3 tenths quicker than the 5.0 5 speed. but once again this is a waste of time question that seems to be asked about once a week if not more often. it simply provokes argument and doesn't get anywhere aside from it not being a tech question. it end's up being a prefference between having a stick and having cubic inches.
Old Sep 29, 2001 | 01:59 AM
Kyle F's Avatar
<font face="Verdana, Arial" size="2">Originally posted by RB83L69:
</font>
Ooops you for got the TTA when speaking of the fastest set up.
Oh and to all those who think the auto waste so much power... figure this one out. The TTA was almost a .5 sec faster in the 1/4 mile than the proto type TTA that had a 5-speed.
Debate that one out. I will give you a hint it has to do with boost.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Old Sep 29, 2001 | 09:40 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
<font face="Verdana, Arial" size="2">Originally posted by zippy:
but once again this is a waste of time question that seems to be asked about once a week if not more often. it simply provokes argument and doesn't get anywhere aside from it not being a tech question. it end's up being a prefference between having a stick and having cubic inches. </font>
Here here.
Old Sep 29, 2001 | 11:12 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by Kyle F:
</font>
Yes this is true, but only because with an auto there is no time delay for gear changing and the shift points were changed to help keep it in boost.
Did you ever see how fast the 5 speed TTA is on the flats? Oh my ### that thing is fast!
SSC
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
50, 57, ho
