Car won't go into Park
Old Sep 29, 2001 | 11:19 PM
fiveironfrenzy's Avatar
Today after driving I pull into the driveway and it wont go into Park, its like it's in neutral. Works ok in Drive and Reverse, except it jumps a little when putting it in Drive. I thought that might be a tranny mount, but could that be a bad cv joint and would that keep it from going into Park?
Old Sep 29, 2001 | 11:24 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
There are no CV joints in 3rd gens, just U joints. (you didnt state what kind of car, so I'm assuming)
If the cable isn't binding and the lever is moving all the way to the park position...it could be the park pin broke in the trans.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited September 29, 2001).]
Old Sep 29, 2001 | 11:29 PM
Sorry about that. 86 IROCZ 305 TPI. If it is the pin is that an expensive fix?
Old Sep 29, 2001 | 11:54 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Don't really know, I send all my internal tranny stuff to a buddie of mine.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Old Sep 30, 2001 | 01:58 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
I'd jack her up and go under (safely) and physically push the linkage to park and see. If it's not locking the back tires, drop the pan and check the park rod, It travels alongside the valvebody from the linkage to the back, where a mushroom cam pushes a 3/8" think or so chunk of metal into the case to engage it to lock it, you could check and see if anything snapped or wore off it. I believe (off hand) it's roll pinned in and has a spring to force it into the case. Maybe something came undone. Otherwise it's difficult getting into there to take things apart, but can be done w/o dropping the v/b.
1992rs/ss
Jan 31, 2025 05:10 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
kyleb24
Aug 15, 2015 08:24 AM
ZsTransAm
Aug 11, 2015 07:30 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
